跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Lock Button slowly not responding
The Lock Button on my iPhone 5 is starting to slowly not response when I push it. I've read it's due to manufacturing defect. Unfortunately, I'm guessing my phone is now past the limited warranty period (which I'm confirming on Monday.)
My question is can it be repaired using the iPhone 5 Power Button Replacement Guide or not?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks, Tom Chai. I completed the "Audio Control and Power Button Cable" guide and it solved my problem. See: iPhone 5 Audio Control and Power Button Cable Replacement
完成的
添加一条评论
3个答案
已选择的解决方案
No. The correct one is "Audio Control and Power Button Cable". The power button is just a piece of metal that pushes the actual switch underneath it.
这个答案有帮助吗?
得分 1
添加一条评论
trocar o midi flex do botão de bloqueio de seu iPhone 5
这个答案有帮助吗?
得分 0
添加一条评论
I have to depress the power/lock button on my iPhone 5 at the far left to make it connect. Do you think a new cable is needed or should I try to run through the steps of replacing the plastic button to see if there is any dirt preventing a solid connection?
Thanks!
这个答案有帮助吗?
得分 0
2条评论:
new cable will solve the problem. apple made a low quality cable on this phone. very common issue
完成的
Thanks Vlad, I'll give this repair a shot.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,324
