Replaced the filter in my KitchenAid fridge with a new one - specifically, "EveryDrop by Whirlpool Refrigerator Water Filter 4 (Pack of 2)" from Amazon. It worked for a day or two, and then the water stopped flowing, accompanied by a very loud, annoying, disturbing jackhammer sound. In addition, upon removing the filter, the refrigerator's filter head (i.e. the "nipple") would leak water non-stop until either a filter or bypass plug were inserted, creating a big mess.
I called a repairman. He inserted a bypass plug, and the water ran fine. Because the bypass cap was long ago lost or thrown away by someone, I could not test this myself. He concluded that both of the filters I bought were defective, charged me $120, and went on his way. This smelled bad, but I had no information with which to counter the decision.
At the suggestion of someone here, I put the filter in a bucket and filled it entirely with water, forcing out all the air within. The effect has been threefold: first, the jackhammer noise can now only be heard for a couple seconds, then it goes away; second, the water now runs, albeit very slowly; third, when removing the filter, the filter head no longer leaks water. I'm very grateful for the latter, because now troubleshooting is less messy.
So, I've decided to live with the crappy water pressure and brief jackhammer sound. Between the overpriced OEM filters, the "repair" job, and a replacement bypass plug, I am about $220 in the hole. I'll wait until the filters give out before trying to contend with this problem again.
This issue is all over the Web, and I do think the most common cause is a bad product. Simply replacing the filter shouldn't break anything, but it does. I don't have a technical explanation for the issue, but it could not have been a coincidental, simultaneous failure of the refrigerator, or my home's water system. It must be a problem with come kind of interaction between the fridge and the filter.
35条评论
thanks funshine45 that was the solution to my problem! I thought all these other solutions sounded like over kill! After a new filter installed on a refrigerator that was working fine - both water and ice suddenly needs all these parts replaced and a repairman (and a big bill!) that would make a fellow never want to change water filter again!
由 James Thompson 完成的
Make sure you check the nipple where the filter goes. if it's not getting all the way pushed in you will get a trickle of water or nothing.
由 myronnieboy1 完成的
Thank you, thank you, thank you! Proper alignment is the key. I actually had to un-tighten a bit to get the water to flow.
由 John Bochenek 完成的
I found the problem to be that I screwed the replacement filter in too tight. By unscrewing the filter counter clockwise ever so slightly, the water flow resumed back to normal.
由 Teresa G 完成的
I bought the HDX filter for my Samsung fridge from Home Depot. After a few minutes, the water completely stopped. Like some others here, I had to loosen mine a bit and water started flowing again.
I think I am going to skip 3rd party filters from now on.
由 Mubashir Cheema 完成的
显示更多的30条评论
