跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
sim reader is screwed
hi
i just encountered this site and u guys are doing a fabulous job.
i have an issue with my iphone from past 3 months.
i did not used it because i dont know how to fix the p[roblem.
the problem is that one of the strings in the sim reader is displaced from its actual position. when i insert sim tray the bottom part is broken and was struck in there. i can see the metalic part of the reader through the vent.
i think replacing sim tray will resolve the issue but i cant find a tutorial to replace it.
i really appreciate if some one could post a tutorial for fixing this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
well, have a look at the teardown - it should help.
at http://s1.guide-images.ifixit.com/igi/ZC... you see the mainboard with the sim holder - should be fixable if the original contacts are still ok, but you my not be able to remove the sim card depending on your fix.
这个答案有帮助吗?
得分 2
添加一条评论
The sim card does not activate when I put the sim card in the phone. I have replaced the tray with a new one but it still does not read it? Can you help me?
Otis Hughes
812-655-1881
这个答案有帮助吗?
得分 0
1条评论:
My note 2 is doing same thing n it was working just fine, then i switched sim cards n now it wont read sim, help plzzz if u know how??
完成的
添加一条评论
添加你的答案
umesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,936
