跳转到主内容
加入维修社区 - 创建账户
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Dropped my IPad 2 now screen is alle green with Lines .
I Can se the apps and acces Them.
It read the Q and A, regarding The IPAD 1 about, and gently hit firm on the corner, screen almost came back to normal. And re attachinf the screen Cabel again.
We played a video and 2 minuts into it, screen turned all Black , with a Grey field Rolling from left of the screen towards the middel, and the starting over again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Hi my little girl dropped her iPad has blue and green lines on it . And fuzzy I can switch it in and off can any one help please
完成的
Hi I dropped my IPad from a little height and my screen went green and hazy, thank you so much for your advice it took ten smacks and to my surprise its back to normal . I'm so thankful to your advice! Thank you so very much
完成的
添加一条评论
13个答案
已选择的解决方案
you could try a light tap on the back were the apple logo is. this area is the location of your display connector. 9/10 it works but if not you would have to take the screen off and reseat the cable.
hope this works.
这个答案有帮助吗?
得分 9
7条评论:
Thanks for this info. I've had my ipad 2 for a couple of years now and I dropped it a short distance and it did this. I hit the back with my fist (not real hard, but not real light) and it worked!
完成的
Brilliant! Thank you! Was worried I had completely broken my iPad 2 but this did the trick. I'm very relieved
完成的
it didnt work it still is showing that grey line and black screen
完成的
can somebody help??
完成的
@kkbelle if want you can start your own post with some details of your situation and see if we can get it working.
完成的
显示更多的2条评论
添加一条评论
In case the issue comes back, or is not fixed by lightly tapping on the outer shell, step two would be to remove the digitizer (the external glass) and the LCD following instructions posted here, then re-assembling the whole thing:
Option 1: after ordering a new LCD display cable connecting the LCD to the logic-board (steps 28 and 29 of the guide), changing it, and securing it with (preferably Kapton) tape.
Option 2: without changing the old display cable, but at least removing it from both connectors (on the logic board AND the screen), then reseating and securing it with Kapton tape. You have to test it to make sure that disconnecting it and reconnecting did fix the issue before re-assembly.
Note: by securing the display cable, I mean putting a small piece of tape over the latch of the cable, to prevent it from popping up and/or preventing the tip of the cable from moving (ever slightly) about, which causes the display to malfunction.
This cable connects the logic board to the retina display screen.图片
产品
iPad 2 Display Data Cable
这个答案有帮助吗?
得分 1
添加一条评论
So I tried hitting it softly when it turned green and nothing happened, then my big sister hit it a lil harder and still nothing and then my baby sister hit it n knocked the $@$* outta it and BAM it was fixed!!
(HIT IT HARD AS !&&*) that always gets the job done!
这个答案有帮助吗?
得分 1
添加一条评论
I put my iPad face down on my sofa as suggested here. Hit it firmly on the logo and presto! Thanks guys for confirming that this worked. I wouldn't have believed it enough to keep trying otherwise.
这个答案有帮助吗?
得分 1
1条评论:
I had it in a suitcase. tried to start it, but only got a gray rolling screen. Read these comments, put it on a desk, rapped firmly with my knuckles - and presto!
完成的
添加一条评论
Seems like your inner screen (LCD) has gone. All you need to do is to order a replacement screen online and fix it using online tutorials available on you tube but if you are not confident about your technical skills then take it to some hardware shop.
这个答案有帮助吗?
得分 0
添加一条评论
Miraculously the (not so) light tap on the Apple logo worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
Again a drop and my screen had green overtones. I followed the answers, put my ipad screen down on the bed and then a hard, with the heel of my hand, strike on the apple. All OK again now. many thanks for the advice.
这个答案有帮助吗?
得分 0
添加一条评论
Love you man! You saved me the expense and effort of replacing the screen or a trip to the Genius Bar. I rapped on it hard with my knuckles, a little skeptical re: this. But it worked perfectly! It's not a tap, not a punch. It's a hard rapping right on the apple logo.
Thanks again!
这个答案有帮助吗?
得分 0
添加一条评论
Worked for me as well. The iPad dropped from a viewing position to flat on a table and began to show lines across it with a shade of green. Wife suggested genius bar, etc. THIS ANSWER worked Great! Placed it face down on a soft surface (dog bed) and gave it a good hit with the edge of my palm. It didn't work the first few times but I increased the intensity and VIOLA. Thanks for the hlep
这个答案有帮助吗?
得分 0
添加一条评论
I tapping worked for me too but the image is not completely clear, the background image is a little pixelized.
这个答案有帮助吗?
得分 0
添加一条评论
this didnt even work this is sometrash advice
这个答案有帮助吗?
得分 0
添加一条评论
It's advice and his option just like @%^$$@$# everyone has one but take it or leave it. Don't be hard on a person be thankful they took their time of of their busy day to post this video. Well thank you I'll work on my ipad
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for posting! I do appreciate it weather this works for me or not it's the effort
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Soren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 49,063
