跳转到主内容
Guides and repair information for Power Macs (previously known as Power Macintosh) including G3, G4, and G5 models.
447 个问题 查看全部
Boot Chime, but no video on monitor.
After changing my PRAM battery, the powermac booted up normally showing me a question mark on the screen. Turned it off and turned it on again after a short time, however this time it started up but nothing showed up on the monitor. What could this be ?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The first question mark showed that it could not find a operating system. Either corrupt system folder or a failed hard drive. I would check and reseat the video card. A black screen can also result from a drained battery or improperly installed battery.
这个答案有帮助吗?
得分 2
2条评论:
Yes that is when i turned off the mac to get an OS to try and install it. Tried reseating the video card but no luck. Tried taking out the PRAM battery and putting it back in but no luck. Before when i had the dead battery, it wasnt doing the chime, but now it is. Could it still be the battery ?
完成的
Hook up another machine to the monitor and see if it has failed.
完成的
添加一条评论
添加你的答案
julianbugejacoster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 521
