跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
114 个问题 查看全部
Airport range has decreased since repair
I recently replaced my iBook G3 clutch hinges and optical drive. Since I've but it back together I seem to have very limited airport range. In fact I pretty much have to be in the same room. Seems like in all likelyhood i've pinched the airport wire, but before I open it back wanted to see if there were any other suggestions...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Looking at the repair guides I believe you are correct in your assumption. I would open it up and check the airport antenna cable. Ralph
这个答案有帮助吗?
得分 1
3条评论:
it was pinched. problem solved!
完成的
+ Excellent
完成的
voted to accept anwser
完成的
添加一条评论
最有帮助的答案
most likely i would say that you pinched the cable (sorry - sounds totally stupid to repeat you - but thats what i would think)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Flynn Stewart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 841
