跳转到主内容
加入维修社区 - 创建账户
The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
Why isn't my computer turning on?
I've owned my Power Mac G4 for years and years, but about a week ago it didn't work anymore. I have tried resetting the PRAM, tinkering with memory positions, but it kept being the persistent sleeper it is. I resorted to calling Apple but, you guessed it, they said it was out of warranty and I had to pay $55 CAN if I wanted them to give me the slightest of help. If anyone can shed some light on this, it would be greatly appreciated.
P.S: I guessed it could be the power supply or the fuse but I didn't want to buy new stuff while I have no idea how to put it together. I would thank whoever can give me some directions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
A list of symptoms would help us to diagnose your problem.
完成的
I can't turn it on. The fans, the lights everything is irresponsive. Like I don't even press the button.
完成的
I forgot to mention I replaced it. It worked a month ago when the same happened but it refused now.
完成的
添加一条评论
4个答案
已选择的解决方案
The first thing I would do is replace the 3.6 volt Lithium PRAM battery, if it's bad the computer will be unresponsive.
这个答案有帮助吗?
得分 1
添加一条评论
My mac is the same way except I put new ram in it and it quit on me!! I replaced the PRAM and nothing. Can somebody help me?
这个答案有帮助吗?
得分 0
添加一条评论
Our G4 was similarly not budging, EXCEPT there was just the hint of a tick sound, every second or two.. Can you hear any sound whatsoever?
With ours, we did the scary-anti-lawyer step of opening the box, with strongwilled intention to not touch anything, just look, and sure enough when we plugged in the G4 and watched, you could see a tiny flash every second or so that corresponded with the ticking. Unplug electric cord because answer is clear. It's not the power supply as many thought, nor the pram, etc.
The good news is that seeing is useful. The not-so-wonderful news was that the flashing was an obvious sign of a fried logic board, which we then found a replacement online and see the replacement steps here at ifixit.
best wishes... ttyl
这个答案有帮助吗?
得分 0
添加一条评论
On the mother board, there is a tiny switch. It's position and label has varied from model to model. Press it ONCE. This will reset the power circuit and it should start up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 2,527
