跳转到主内容
Guides and repair information for the 4th generation of the BMW 7 Series / E65, E66, E67, and E68 platforms.
23 个问题 查看全部
passenger rear side tire seems to wear unevenly
the rear tire on the passenger side wears more than the driver side
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I second this! Just got my second rear passenger side tire in less than 7.5K miles. I also have off-setting front and rear tires and the back rear passenger tire seems to rub on the outer side of the wheel well. Getting an alignment and will let you know if things get any better.
完成的
添加一条评论
1个答案
已选择的解决方案
BMW tires normally wear a lot more on the inside than on the outer edges, because of the way the suspension is set up.
You probably need an alignment, or something is bent in the suspension. Posting pictures may give us a better idea.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
al bettencourt 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 1,199
