跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
118 个问题 查看全部
Recovering lost files from emptied trash.
I threw a documents file in the trash, thinking I'd duplicated it, and then emptied the trash.
I've lost the whole thing.
Can anyone advise me how to go about recovering the lost file?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
10个答案
已选择的解决方案
Here is one solution--good luck. Ralph
http://www.squidoo.com/recovertrashmac
这个答案有帮助吗?
得分 4
1条评论:
nice app +
完成的
添加一条评论
Hey, you have to use some data recovery program that can work on Mac
这个答案有帮助吗?
得分 4
添加一条评论
I use Data Rescue 3 and can recommend it.
http://www.prosofteng.com/products/data_...
这个答案有帮助吗?
得分 2
添加一条评论
If you want to try data recovery apps for free then you have plenty of options available for Mac. Go for Stellar file repair http://www.stellarinfo.com/mac-osx-recov..., try disk drill for Mac http://www.cleverfiles.com and Softtote Mac recovery http://www.softtote.com . Trying more than 1 tool will help you evaluate & compare the recovery performances. Go for the one which gives back maximum recovery figures.
Get back to me for more info.
这个答案有帮助吗?
得分 2
添加一条评论
Even if you have emptied the trash then also you can recover your data. Remember permanent deletion of data takes place only when the data is overwritten by something else. So, you need not to worry just use a data recovery software you will be able to recover the data easily.
这个答案有帮助吗?
得分 1
添加一条评论
can i get my photos back from the trash i have delete ?
这个答案有帮助吗?
得分 1
添加一条评论
Accidental deletion of files from trash is common but to know how to get back deleted files is not restricted to only technical experts. I read an article that help me to get back files emptied from trash bin and trust me the solution is much easier.
The article goes here -
http://www.stellarinfo.com/support/kb/in...
这个答案有帮助吗?
得分 0
添加一条评论
thanks i have learn things a lot
这个答案有帮助吗?
得分 0
添加一条评论
I used Remo Recover (Mac) to recover all of the files that where lost due to usage of Empty Trash folder option.. Hope it helps you too.
这个答案有帮助吗?
得分 0
添加一条评论
The best solution has lost the page. There are still some ways to try before using the data recovery tool. For example, use the Mac-specific Time Machine feature:
1. Start "Time Machine" > select a way to transfer files and continue.
2. Select "Backup" to confirm the action and continue.
3. Carefully confirm the time and date of the backup and select the appropriate backup.
4. Select the file you want to restore and click “Continue” to start the transfer process.
After the transfer process is over, check if your file has been restored. If it hasn't been recovered, don't hesitate to choose a reliable data recovery tool to recover lost files from emptied trash as soon as possible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
frances plowden 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 4,027
