跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Center button issues (minor water damage?)
Hey guys,
So I took an 16gb 3G off of my grandfather's hands in an effort to sell it (as he had two for some reason). Anyway... I soon find out that the center button works about 75% of the time and sometimes refuses to work for a few hours - its under warranty but when I take it to Apple they tell me water must of sneaked up the charging area and therefore the warranty is no good.
The phone works in perfect condition other than this minor problem which only seems to happen every once in a while..... is there anyway to fix it? What am I looking at in terms of costs? Any insight is appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Have you opened it up at all? You may want to take a look and see if any H2O is in there.
完成的
添加一条评论
2个答案
最有帮助的答案
well, sell it with the known fault honestly to the buyer
or FIX it yourself and end up with a phone that may not be any better and has a damaged shell.
if it is as you describe, someone easily will buy it as is, as opposed to a 'attemted fixed' one
这个答案有帮助吗?
得分 1
3条评论:
Being dishonest doesn't solve anyone's problem.
完成的
NOWHERE did I say to be dishonest - I said to tell the buyer about the problem. I basically said don't %^$^ with it and make it worse ....
完成的
11team is Correct selling the phone on ebay with the know fault described is a good idea and is NOT dishonest.
完成的
添加一条评论
Can ifixit fix it?
这个答案有帮助吗?
得分 -3
1条评论:
iFixit does not personally do repairs. Sorry!
完成的
添加一条评论
添加你的答案
Cody 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 3,216
