MacBook Pro randomly shut downs
I have a 15" MacBook Pro a1150 that I am having some problems with, it shuts down randomly. I don't know what it could be, there doesn't seem to be any rhyme or reason to it. I don't think that it's overheating, I installed a fan application and it seems to run between 130-150 degrees F.
3条评论
I took the battery out and have not seemed to have a problem with it since.
由 Trent 完成的 分享
mayer - I downloaded the application and the it says the battery is at 76% of original capacity and has about 285 cycles on it. It seems to just happen as long as the battery is in the computer, if it is running solely on battery it does it, if the battery is in and it is hooked up to the charger it does it, however if the battery is out and it is hooked to the charger it seems to run fine. I restarted it with the battery and it started fine, then I took the battery out and it restarted just fine too.
由 Trent 完成的 分享
I am having this issue now, on a Mac I have literally JUST updated to Snow Leopard. It didn't do it before? As in an hour ago??
由 Sander Koop 完成的 分享
