跳转到主内容
The Powerbook 520/520c is equipped with a 25MHz, 68LC040 processor and a passive-matrix display. The Powerbook 540/540c is equipped with a 33MHz, 68LC040 processor and an active-matrix display. A 'c' indicates that the display is in color. Both units list M4880 as their model number.
1 个问题 查看全部
Accessories needed to connect to the web?
What do the parts look like that connect this ancient laptop to the internet provided by the cable company?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Wired:
You'll need an AAUI to Ethernet adapter. You can find an official Apple adapter on eBay, or a generic one for less. These aren't terribly difficult to find, but aren't common enough to find in a local parts store.
Wireless:
Method 1: You'll need the Apple PC Card Cage and a PC Card compatible with Apple's Airport card (to make it easier). The PC Card Cage is very hard to find and expensive if you find it. An ORINOCO PC card is relatively easy to find and cheap.
Method 2: Using the AAUI to Ethernet adapter and a Ethernet to WiFi adapter. You can find a battery-powered Ethernet to WiFi adapter, but all these adapters won't make it easy to move around.
这个答案有帮助吗?
得分 4
1条评论:
My mistake. This machine does not have an ethernet port. Miles Raymonds answer is the correct one. I have deleted my answer.
完成的
添加一条评论
Frankly, I think its safer not connecting to the internet.
This systems OS has quite a few security holes, sadly you can't upgrade it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 538
