Two SSD Drive Raid 0
Just wondering if it is possible to install 2 SSD into Mac Mini Late 2012 model and do a RAID 0 ?
I bought 2 kits from ebay and none of them able to detect the "Upper" SSD.
Is there any differences among those cables ?
Apple does have a problem with both the Mountain Lion installer as well as within the systems BIOS (EFI).
这个答案有帮助吗?
Is this an answer or a comment?
Answer per Apple - See other Answer for the background SSD will not show up after installing
After reading through all the info on the other question, I take it that the answer is "No" right now.
Yes, it's no for now.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 2,416
2条评论
There does appear to be an issue with a double SSD setup refer to this question: SSD will not show up after installing
由 DanJ 完成的
As I expressed to Radjin someone with the setup needs to speak to Apple as it does appear the ML installer has an issue and I suspect the EFI firmware may as well here.
由 DanJ 完成的
