跳转到主内容
The Nokia E71 is a smartphone from the Eseries range with a QWERTY keyboard targeting business users worldwide. It was released in 2008.
6 个问题 查看全部
How to get the cover off Nokia E71 to remove dust
Is there a good way to pry off the front cover so that you can dust off the screen underneath. Worried about cracking some connectors if I go about it the wrong way. Pretty tight fit and not sure if it is designed to be taken off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I hate to just Google it for you, but I Google'd it for you. Here it is :
Nokia E71
Regards,
Frank
这个答案有帮助吗?
得分 3
2条评论:
Thanks! (Feel really stupid.....)
Good photo guide. Note: you will need one of those special octagonal screwdrivers (the tiny ones) to undo the screws in the second picture
完成的
"special octagonal screwdrivers" - it's called Torx - the size in that case was T4 ;-)
完成的
添加一条评论
Look for this procedure:
Disassembling Nokia E71 Complete disassembly
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tze Wen Leow 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 11,931
