跳转到主内容
The Pioneer DEH 4600 MP is an in-dash car stereo that is CD, MP3, WMA, and WAV compatible.
12 个问题 查看全部
Why does my Pioneer stereo not produce any sound?
I recently attempted to install my pioneer car stereo into my 99 Jetta. The first time I turned it on after install, I heard a spark. Looking closely, there was an exposed wire that had come in contact with the stereo's outer casing.
At this point, the stereo doesn't send any signal to the speakers. The unit powers on and reads CD's just fine, but refuses to make any kind of sound. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
12条评论
replace your pre sound IC it would cost you around $10
完成的
I recently hooked up a new deck in my truck. It is hooked up to an external amp and i can get the bass of my amp and subs but no treble from my stock speakers. Theres no exposed wire that isnt electrical taped and everything seems to be hooked up correctly. Any suggestiins?
完成的
Have a pioneer bhv-x381 bt deck plays on blue tooth & cd just fine but no regular radio no sound new, deck ideas plz
完成的
Hi Paula Overton,
Check that the aerial connection is OK. Do you get any sound when selecting AM or FM such as 'hiss' in the speakers?
Have you tuned in the stations?
完成的
My carrozzera pioneer not producing sound . can I import presound ic, where? Model Ivic-zho99g
完成的
显示更多的7条评论
添加一条评论
5个答案
已选择的解决方案
Sounds like you might have blown the amplifier in the deck. Hook the RCA outputs into an external amplifier of some sort and see if there is sound there.
Also, I second markus on check all the wires. Plus this time before you put it back in be sure to cover all non used wires with tape or something to prevent shorting. The amplifier turn on wire shorting for example has been the cause of many blown decks.
这个答案有帮助吗?
得分 7
20条评论:
I recently hooked up a new kenwood deck in my car but it only plays front speakers and sub , wont play 6 by 9s at all .so i hooked the old one up and they all worked even the 6 by 9s , any ideas?
完成的
Hi @chevybass ,
What is the model number of the kenwood and what is the make and model of the car?
Did you need to use a different adapter cable from the deck to the car's audio wiring plug?
Also you may get better responses if you ask your 'comment ' as a new question, rather than on a 7 year old answer as it might not be noticed here by many . Give the extra relevant information as I asked ;-)
完成的
It is a kenwood kdc bt365u and it had the same adapter so i didnt need to rewire it , my car is a 2008 chevy malibu lt
完成的
Hi @chevybass ,
Have you checked that the 'speaker size' settings are set correctly in the deck?Here is a link to the User Guide (which you probably have got) for the unit. Go to p.21 to see how to get to the audio settings for the "Speaker Size" - Front - Rear - Woofer and check that the settings for the rear speakers are OK and are not set to None
完成的
Got it set to 6by 9 and nothing
完成的
显示更多的15条评论
添加一条评论
hi, i've looked around a little bit
it could be blown power amp but it could also be a cable problem
if a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp
remove all cables and put them back to the radio - connect the speakers one by one to see if it works or mutes again
这个答案有帮助吗?
得分 4
3条评论:
Ok, I have pioneer sound system which now seems to have a problem of function completely. Funny thing it does go on and off but nothing else. No radio functionality, doesn't open the disc compartment, nothing. Just on and off. Any help out there anyone
完成的
I just had the same exact thing happened that's what brought me here had a wire arc then a pretty weird smell so pretty sure it fried the board or the internal amp I guess...%#*!^@ man
完成的
I do hear some sound coming from the speaks like white noise so if anyone got any suggestions let me know....thanks
完成的
添加一条评论
This is what I would do given the information! Some wiring in cars do not hook directly into aftermarket stareos. Check with a spair speaker to see if your deck is working. If it is, then the problem is in the wiring to the car and you mmost likely need another adapter. If you had sound before the spark, then it is most likely your amp. In this case, include an amp into your sstereo configuration and problem solved.
note, some car audio has power amps built in and can have blown/burnt fuse due to the spark, however unlikelydon't forget about that
这个答案有帮助吗?
得分 1
添加一条评论
which Ic using for power amplifier?
there is a luck test ... if the ic is not blown but not powering on , then take a relay (12v) connect one side of relay coil to deck grount , and next coil just touch and release to vcc pin of amplifier ic , the relay makes a 'tick' sound , as it produce some back emf there is a possibility of switching it on , in my case it works .. I has the same prob with my chevorlet inbuilt radio...
这个答案有帮助吗?
得分 1
1条评论:
heyy im also facing the same problem i remobed the IC it was toast bt then i lost it now i donno the type to buy for a DEH1850Xub
完成的
添加一条评论
My pioneer radio does not have front and back speakers settings and it has leftband right
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brett Hartt 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 67
过去 30 天: 266
总计 170,539
