跳转到主内容
加入维修社区 - 创建账户
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Need passcode for Migration Assistant - Solved
I have a customer with a new 2013 i5 MacMini running 10.8.3. She wants me to transfer her data from a Power Macintosh G5 2.0 DP running 10.5.8. I downloaded and installed the Migration Assistant Update for Mac OS X Leopard v1.0. When I put the G5 in target mode the hard drive icon shows up on the desktop of the Mini, but Migration Assistant will not mount the drive. When I put the Mini in Target mode, Migration Asst. asks for a numeric PASSCODE. Not a password. You would think this passcode would show up on the Target screen but does not. How do I find this Passcode?
Solution
Hook the machine up via Firewire cable. Start up both machines but do not use the Target Mode key. Start up migration asst. on both machines. Select "From a Mac on one and "To" a Mac on the other. A five digit Passcode will appear on the screens of both machines and they are now ready for data transfer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Mayer -
Checkout this Apple TN OS X: About FileVault 2 and MacWorld - Complete Guide to FileVault 2 Are you getting prompted for the Recovery Key? Which is a five digit number.
这个答案有帮助吗?
得分 1
3条评论:
It looks like a five digit code but calls it passcode. I think, in the morning, I'll put the hard drive into an Intel MacPro and upgrade the system to 10.6.1, then see if it will work.
完成的
I have a faint memory of it being called "Passcode" in the older version of FileVault, but I'm not sure (never used it, but went to a training even on it years ago). Does she remember using it or some other encryption app on the HD?
完成的
Customer has no memory of ever using FileGuard.
完成的
添加一条评论
OP solved Question: Solution
这个答案有帮助吗?
得分 1
2条评论:
FireWire connected HD's haven't prompted for a passcode with Migration Assistant in the past. I could see that if you used WiFi or Ethernet as you could have other systems present on the network. How odd... Is this a new thing in newer versions of it? I haven't used it in quite a while.
完成的
Dan - It was new to me. After the transfer I will hook them up in Target mode but not use the "T" and see if they now see each other using just the FireWire cable, but I've got a five hour transfer wait.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 2,270
