跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4s not turning on after screen replacement
I replaced my friends iphone 4s screen I put it all back together but when i try to turn it on it does not go on I disassembled it again to check all connection and assembled it again but it still wont turn on i have tried 3 times but nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论:
Hi. Does it turn on if you put the charger in?
完成的
No it does not turn on
完成的
have you tried the old screen back in the iPhone? it could be a fault with the screen or as some of us are finding the screen is ok, phone is ok, they just don't like each other..
完成的
I put the old screen on aswell but it still didn't turn on
完成的
添加一条评论
2个答案
Hey fella,
There's a chance you may have damaged the battery connector. Try plugging the
iPhone into a computer, if it's recognised after a few minutes you could have been sold a dodgy screen. Or it could just be that the process has completely drained the battery and could need charging for a bit, try plugging it in for around 10 minutes, if you don't get any response unplug it to prevent any further damage. Or take the battery out and check the ribbon, there's every possibility that you could have torn it, even the slightest tear could render the battery useless. As well as this, make sure that all of the connections are properly seated at their points.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
Hi! I just joined the iFixit community and hope to help you!
There is a few things that could've happened, if you smell a strange smell from the phone you could've poked the battery and will need to be removed, if that is not the case you could have damaged the logicboard from incorrect screws, if that does not work then there might be water damage if there is none, then the flex cables are broken or the logicboard is done, I have fixed a 4s after I took off the screen it smelled like smoke and was over heating and not responding and best guess is the phone was gone because the whole front and back was broken and I replaced both and still no luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sergii1414 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 2,082
