跳转到主内容
加入维修社区 - 创建账户
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Homebutton assembly differences throughout iPad generations
Hi guys!
I was just wondering:
I know that the iPad 4 comes with a new flexcable which is easy to be damaged during the process of removing the touch assembly.
As far as I know, the assembly consists of:
-the physical homebutton
-the mounting bracket
-the hold-thingy which will be glued to the touch assembly
-the flex cable
Since the main difference is the new flex cable, my question is:
Are the other parts of the assembly the same/compatible throughout the generations 2,3 and 4?
So could I use the same physical homebutton in an iPad 4 aswell as in an iPad 2?
Same thing for the mounting bracket and the hold-thingy (sorry for the unprecise description, English is not my mother tongue)
Thanks for your help!
Regards from Germany,
Jonas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The electronic switch is the same for Gen 2 and 3. I'd say that all three of the current generations share the same adhered mounting brackets and home buttons. Only the 4 uses a ribbon because the new port isn't "wide" enough to contact previous Gen electronic switches.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much!
That's what I thought, thanks for the confirmation.
Had to configure a homebutton assembly for my repair shop and wasn't quite sure, got confused because the homebuttons of 2-4 seemed to be same though they had different numbers on their backs.
完成的
添加一条评论
添加你的答案
Jonas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 24
总计 192
