跳转到主内容
The Epson Stylus NX415 is a color inkjet printer. The printer uses T088/69/68 ink cartridges, which use a wetness sensor behind the visible primary chip.
4 个问题 查看全部
How do I bypass this general error?
I was just gifted an Epson Stylus NX415 hoping to use it at least as a scanner but when I power it on I get this error on the LCD display:
Error:
A printer error has occurred. Turn off the printer, then press On button to turn on. See your documentation.
I've checked the user guide and can't even find this status message listed in the documentation. When I try to power cycle the printer I get the same error. I've tried booting it with and without paper loaded.
When I have the OSX System Preferences panel open it lists the printer as on but idle:
And within the printer utility I get "General error," which is likely one of the least helpful error ever. Ha!
Is it a firmware issue? If so, does anyone know how to reset the printer to factory settings?
Cheers!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
If you already have turn off and turn on the printer and error doesn't clear up, try turning it off and check for any obstructions that may be blocking the inks from moving then turn it on. If the issue persists, your printer already has a hardware issue particularly the printer part of your product. I suggest that you contact Epson for a replacement printer if it is within the 1-year warranty period from the date of purchase. Or Check Out This Link For More Help http://www.fixya.com/support/t11620251-e...
这个答案有帮助吗?
得分 1
1条评论:
Thanks Harvir! It looks like it is a hardware issue. I'll call Epson on Monday. Cheers!
完成的
添加一条评论
It may happen after a load of ink clogs your paper sensor.
这个答案有帮助吗?
得分 0
添加一条评论
i have problem with Machin epson l800
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tod Robbins 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 8,634
