跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4S Display Assembly not working with iOS smaller then iOS 6
Hi,
the last 2 weeks, we have the problem, that our replacement display assemblys for iPhone 4s are not working if the ios is smaller the 6.0.
The display stays black, Touch and Backlight are working. Do you know the problem. How to solve it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
same problem too..not solved by upgrading iOS either! screen works in other iPhones. Completely stumped!
完成的
bottom home button & top reset button both press & phone working
完成的
添加一条评论
4个答案
已选择的解决方案
I am having the same issues...It seems that the new screens prevent the phone from booting up. But if the phone is booted with the old screen, and then if you hotswap the screen while the phone is asleep, the new display will work.
This prevents you from shutting the phone off
I had 3 different screens from 3 different manufactures and 2 iPhone 4s', both exhibited the same issue.
这个答案有帮助吗?
得分 4
2条评论:
I agree with Taylor. The solution to this is to swap the screen with the phone on but screen off. I've had it happen with a few iPhones and iPads..there is nothing wrong with the screens or the boards.
完成的
But is there any other permanent solution?
完成的
添加一条评论
I think I would be contacting your vendor about that. It's not really a repair issue as much as it is compatible part. We see this often with computer HD's new ones claim to be backward compatible but then are shown not to be.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
3条评论:
but when you update the iphone the screen still won't work..the screen will work in another phone. Why would the screen work on one phone with iOS 6+ and not another on the same iOS? Remember that another screen will work... This problem is a little like the battery issue for iPhone 3GS and it would cause boot loop etc if you didn't install the correct serial numbered battery. It'd be nice to know what the issue is here so we can order the right screen for the right phone x
完成的
Another 4S running IOS6+? Could there be hardware damage other than the screen you overlooked?
完成的
No. Another screen and the old cracked screen worked. It's very odd.. Not motherboard damage.
完成的
添加一条评论
Any solutions for this problem. I'm starting to see a lot of phones with this problem even with ios6 and later. If I run an old screen it works. None of my new screens will light up but they work fine on other phones.
这个答案有帮助吗?
得分 0
1条评论:
Only solution so far is to replace screen with phone on instead of off as we normally advise...similar problem with ipad4 screen replacements :-(
完成的
添加一条评论
Same problem with an iPhone 4 with iOS 5 but another one witch iOS 4 worked ! 2 screens tested, same issue with both, solved by an upgrade to iOS 7.2
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,938
