跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Volume button screw is stripped
I've been following the instructions to replace the rear panel on an iPhone 3G I'm experimenting with but when I came to remove the volume screws on the inside (4 of them) the middle one is well and truly stuck and I think I have now stripped the screw back through sheer frustration. Any hints?
VMT
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
small drill bit and drill the head off. then you can just pull the screw out with some little tweezers etc. there are other suggestions on here...just search for stripped screw. try the next size up PH or get a flathead instead?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 122
