跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
sleep wake button not working
hi, the sleep/wake button on my first gen iPod touch wont work, i cant put it to sleep. so the battery dies within hours.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
10个答案
最有帮助的答案
Try holding the sleep and home button at the same time. Hold them until you see a white apple appear on the screen (ignore the shutdown screen and keep holding the buttons until you get to the white apple. REMEMBER HOLD TILL THE WHITE APPLE!)
When holding the buttons for a hard reboot you will see:
Screen with shutdown message and slider
black screen
White apple screen
It might just need the hard reboot.
这个答案有帮助吗?
得分 2
添加一条评论
I cant even get my iPod touch to restart by holding the sleep/wake button and the home button. when i do that nothing happens.
这个答案有帮助吗?
得分 1
添加一条评论
Not sure if holding both would work since the issue is the sleep wake button does not work anyway.
An alternative would be to go into settings > General > Auto Lock > set auto - lock to one minute.
Then when your iPod is not being used it will go to sleep after 1 minute.
Not a perfect solution but better then a dead battery.
Hope it helps.
这个答案有帮助吗?
得分 1
添加一条评论
Did u find a solution? I found that the contact ( a little spring metalic thing ) of the lock button was missing.. i've been searching the web but i dont find any replacement part..
这个答案有帮助吗?
得分 1
1条评论:
i think you mean the iphone - the ipod touch doesn't have a lock button
完成的
添加一条评论
i dont know how to do it but i know you have to get inside the ipod but it cracke's your screen wso i wouldnt try it
这个答案有帮助吗?
得分 0
添加一条评论
My ipod was working fine until the lock button or the top button was not working. So I put it on to auto-lock but I am gonna take it to the apple store to have them look at it.
这个答案有帮助吗?
得分 0
添加一条评论
I can help you diagnose the problem here. First take off your backplate so you can see the battery and logic board. In the top right corner you will see a gold "z" spring. take a small screwdriver and angle it on the ipod touch somewhere that is metal and touch it to the z spring. you need to make a ground, you can even just move it around a bunch trying to make a connection. If the ipod sleeps or wakes up then you just need a flex cable for the sleep button,,
这个答案有帮助吗?
得分 0
1条评论:
if you want to advertise your business, please don't do it on here. Put your website address in you profile.
完成的
添加一条评论
my ipod 2G has the same problem...even worse...the sleep/wake button doesn't respond and it gets in standby when it wants. the screen gets dark and i have to wait since i can wake it again. it drives me crazy!
please help
这个答案有帮助吗?
得分 0
添加一条评论
I was successful in getting my sleep/wake button to work by fiddling with the mechanical button from the inside the iPhone. With the phone charged, you can orient the screen so you can see if/when the button works or does not. There is a small metal strip on the inside of the button that I could gently push up (towards the case) or down (away from the case), and this would allow the button to work -- but only intermittently. A permanent fix was achieved by slightly de-torquing (ie, un-screwing) the 2 teensy screws on the underside of the button mechanism. I really just "relieved the pressure" on these 2 screws, I did not really unscrew them at all. This is what worked for me. Good luck. Tom
这个答案有帮助吗?
得分 0
添加一条评论
my ipod does that too, the lock button just dosent click, the volume buttons do, but not that one…
so i have to wait 1 min for it to go off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
whalenp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 18,272
