跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Is iPad 4 LCD the same as the iPad 3?
I know the digitizer for the iPad 4 is the same as the iPad 3. We have repaired iPad 4 and have had no problems. But is the LCD the same connection and part? Can I use the iPad 3 LCD's I Have in stock to replace a broken LCD for a client?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
已选择的解决方案
They are exactly the same, exchangeable completely.
这个答案有帮助吗?
得分 8
添加一条评论
yes, the same. iPad 3 screen will light up just fine in the ipad 4.
这个答案有帮助吗?
得分 7
添加一条评论
Hi,
According to me iPad 4  Pretty much the same as the iPad 3
这个答案有帮助吗?
得分 1
添加一条评论
Interesting stuff to read about iPad mini' display. Keep it up.
这个答案有帮助吗?
得分 1
添加一条评论
The answer is yes, Ipad 3 LCD and Ipad 4 lcd can be perfectly used for each other, which has been verified by Jackie's Apple repair.
这个答案有帮助吗?
得分 0
添加一条评论
Of course different, You can get the answer from this website:
This is iPad 3 screen: http://www.etradesupply.com/apple-the-ne...
This is iPad 4 scren: http://www.etradesupply.com/oem-apple-ip...
这个答案有帮助吗?
得分 -2
5条评论:
WRONG! They are the same. If you do not know, do not answer. People rely on these answers to be right!
完成的
Thank you David. I was confused by this persons reply.
完成的
@soros I recognize that this is a wrong answer, but it is still an answer. We just had a discussion about this very subject on here https://meta.ifixit.com/Answers/View/942...
We should not be the judge about how good or how bad an answer is, for as long as it is not misleading or written with any malicious intent. Feel free to comment on those answers and utilize your voting powers to either validate or disprove an answer.
完成的
@oldturkey03 il keep that in mind.
Still learning the things around here.
完成的
@soros no problem at all. Just something to keep in mind...
完成的
添加一条评论
添加你的答案
SaqibQ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 5,469
