跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
Why would a crack in the touch screen cause LCD to fail?
The touch screen has two small fractures that don't even reach the surface and are only visible from certain angles. I'm not sure if they were caused by a drop or pressure to the glass but the LCD doesn't have any power. The phone systems seem to function along with the lights at the top of the screen. What and why would the LCD fail from cracks in the glass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
10条评论
I also have the same issue, dropped mine the glass cracked and 3 days later the LCD quite working
完成的
@John Page Have you replaced the front panel assembly or done anything to fix it? I'm curious if that fixes the problem or if it is another internal issue?
完成的
Not yet, going to replace the digitizer, looks like its about $200 :(
完成的
Hey John. Did you replace the Display Assembly? Did the LCD work?
完成的
Had an issue finding a black lcd, ordered from on place only to tell me a week later they had no stock, ordered another one today hope to see it in a week or 2, I will post here what my results are as soon as I get it installed. I have been told that Samsung cut production on parts which is why they are hard to find, lots of Blue and White ones available though
完成的
显示更多的5条评论
添加一条评论
1个答案
已选择的解决方案
Finally got it replaced. Everything is working again
这个答案有帮助吗?
得分 1
1条评论:
Thanks John for the update. At least dropping $250.00 will fix LCD blackout. Thanks again.
完成的
添加一条评论
添加你的答案
South30 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,238
