跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Broke microphone connector replacing LCD. Is it fixable?
I recently replaced my MacBook's LCD panel. The panel works great, but in the teardown process I broke the microphone connector off the motherboard (yes, despite the warnings in the tutorial). Is there any hope for fixing this, or am I stuck without a mic?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
As a work around get a USB audio adaptor - or a headset with voice quality microphone - depending on your intended use of the mic. USB audio is separate from analog audio, most adaptors include a mic, and in/out jack ports.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
I tend to agree the first reply would be you're easiest solution.
There may be some hope of fixing it depending how much damage has been done to the motherboard.
I would NOT recommend you try this yourself, unless you already have extensive experience with soldering delicate computer boards and components.
It's not as easy as it looks, especially with this sort of equipment, the motherboard will be multi-layered (probably 4 or 6 layers), not just multi-sided. These circuit boards and most of the components are extremely sensitive to heat, which makes soldering, removing, and replacing components very delicate and difficult.
Cheers Paul
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anonymous 4177 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 126
