跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
No power but light at magsafe
Received a Unibody today. Seller said sometimes boots but so far nothing.
When the charger is plugged in I get an orange light at magsafe and when the battery check button is pressed it seem to be charging.
Removed battery, RAM and checked the HDD in another machine (works) but no joy.
If anyone has any ideas of what next Id be grateful, hoping its not the motherboard as its a nice tidy machine which I will end up keeping if it can be fixed.
thanks
Update
This doesnt look pretty, found this ribbon connector held on with tape.
Update
Stripped the logic board out and its just getting uglier
Looks like its fried
Update
Ive been looking at Logic boards and came across this one on eBay
" Macbook pro 13" A1278 mid 2010 logic board, works on an external monitor, has no led connector on the board(see picture).
Here is the serial number of the laptop from which the logic board was removed: W80436FAATP
You are getting just the logic board(with cpu and gpu on it) and the heatsink."
Anyone know if this one could drop straight in to mine?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
6条评论
Have you tried jumpering across the power pads to see if the keyboard switch was bad? Or check the ribbon cable is correctly seated and not damaged.
完成的
Point me in the direction of how to and where and I'll give it a shot.
完成的
Can you see corrosion on the board? Are the liquid indicators tripped?
完成的
Looks like the keyboard connector socket needs replacing, socket damaged and secured with sellotape. A real pro job
完成的
No this logic board won't work as its for a MacBook Pro not a MacBook which is what you have.
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Yep ;-{
A real pro was at work here.
I would return it if the price was high, if it was low then the investment on replacing the cable & connector won't be so bad.
这个答案有帮助吗?
得分 2
2条评论:
Price was OK, £90. Got a replacement connector off eBay which arrived snapped in half and that was the sellers last one.
Anyone know any UK sellers that might stock the part?
完成的
Ouch! Sorry I'm on the other side of the big pond. You could give these folks a try TheBookYard there located in the UK, over here you could try AppleComponents.
完成的
添加一条评论
you MAY want to check SN of the mac just on the odd chance that its still under Warrenty ( highly doubtfull) . new systemboards are not cheap for macs but also not impossible to source a refurb ..
这个答案有帮助吗?
得分 0
1条评论:
Apple would reject this as it is clearly messed up (if it was in warranty). Besides it's way to old to be under warranty.
完成的
添加一条评论
添加你的答案
kelvin stephenson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 540
