跳转到主内容
The Kindle Fire HD 8.9” is a tablet computer that allows users to read books, view comics, watch movies and find general entertainment at a mid-range price. Fixes are simple and do not require any special tools.
54 个问题 查看全部
Replaced USB Charging port but kindle still not charging. Any Ideas?
I have a Kindle that will not charge. The usb charging port was loose on it, well not loose, it had no connection to the board. I soldered it back into place and put the kindle back together and plugged it in. No change. I further examined the usb port and decided that maybe I should try a new one. Got the part in, successfully soldered to board but still can't get the kindle to charge. I am at a loss right now and need of some help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论:
I have tried plugging it into the computer, a different power supply and wall plug in.
完成的
Have you check the traces on the logic board at the connector for any current?
完成的
添加一条评论
3个答案
Hello!
If the repair was definitely successful then it's time to cross the kindle of the problem list... For Now.
It is possible that the charging unit (PSU) is faulty, have you tried charging the kindle through USB connection using a computer?
这个答案有帮助吗?
得分 0
添加一条评论
Where did you get the charging part from that is exactly what I am looking for.
这个答案有帮助吗?
得分 0
添加一条评论
forget it..... the tiny membrane connectors between the screen half and the bottom part are virtually impossible to connect back properly once you pry apart the case. The device will be destroyed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabi Quaranta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,027
