跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
ipad wont turn on and wont charge ..help me pls
yesterday my ipad wont start after it had an empty battery. the basic troubleshooting steps was 1
did hard reboot, use another charger still no go... try to use laptop but still no power and cannot be sync..
no indication that it is charging and no single light or display.. totally deaad..
try known good adapter and charger still no go.. was just playing a game when the battery was low and the ipad got empty bat. when i came back home i try to charge it but it wont and did many hard reboot. last two weeks the same symptoms came and the power button plus home key presseing work and now i am so sad my ipad has no life.. please help me...
also my memory is low.. never dropped or wet my ipad
hope there is still a light of my problem...
thank so much in advance ...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
did you try to use a different AC wall charger?
完成的
添加一条评论
3个答案
First have a look inside the dock connector and check for any dirt or other objects and clean them out if there is any.
Second I would recommend leaving the iPad mini on a AC wall charger for a few hours and then have another look to see if the iPad is working.
Failing all that, its time to send your iPad back to Apple as it will still be covered by the warranty and since you have not damaged it, you will not want to pay out for any repairs.
Let me know how you get on and which method leads to success, if you need any more help please ask.
Cheers
Brendan Mills
这个答案有帮助吗?
得分 0
添加一条评论
I ipad 2 does not charge or turn on I have tried holding the sleep and the home button on for 10 second nothing happen help please some one from god Is number 1
这个答案有帮助吗?
得分 0
1条评论:
how much will it cost to repair it
do you knw
完成的
添加一条评论
Hi, I'm from Panama, I have the same Problem :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gerome 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 8,826
