跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Mac only types in caps
Anyone know how to fix this and yes, caps is off but still types in caps. I went to system preferences and it looks right. any suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
²naythan
it would always be a great idea to start a new question for that matter.
anyhow - first of all - use your setup disk to remove the password (use this guide (click))
after the system restarted, try to kill the caps lock function, i only guessed this - but maybe the mac "thinks" he had received the caps lock code from the keyboard (keyboards are working with codes)
use this guide (click) to try it
这个答案有帮助吗?
得分 3
2条评论:
+ links
完成的
to kill the caps lock function: https://www.maketecheasier.com/disable-c...
完成的
添加一条评论
did you try to reboot your MacBook ?
i've read that sometimes this could happen and the problem was gone after a reboot.
if a reboot won't fix it - what happen if you switch caps lock on ?
这个答案有帮助吗?
得分 0
4条评论:
I rebooted about 20 times and nothing, when the caps is lit still types in caps..
完成的
I would try the SMC and the PRAM resets.
maybe this could help resolve the problem
完成的
I tried both of your suggestions, didnt work. Im assuming its the keyboard..thank you for trying
完成的
to bad - maybe you should try a usb or bluetooth keyboard before you go out and buy a new topcase
完成的
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 16,704
