跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why isn't the right side of my iPhone 4S touchscreen working?
I first noticed that the right side of my touch screen wasn't working while writing an SMS when I couldn't type the letter "P". It works in landscape mode but not portrait (because it is a different location on the phone.) It works to launch apps but if I need the very right side of the screen it doesn't work. (For example, jumping to a certain letter in contacts or moving an app from the 1st page to the 2nd.) There is no damage to the screen or water damage to the phone. Is there a part that needs to be replaced or a connection that needs to be checked? Thank you in advance for any help or advice you can give.
Keith
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 19
8条评论
@keith i am having the same problem right now, i am using Iphone 4s, please tell me what did u do so that it came back to normal?
完成的
i have the same problem too :( i cant touch the very left side of the screen:( plkease help mo
完成的
@keith i am having same problem what you are facing but i am using iphone 5 please suggest me to fix it. my mail id lazard.mba@gmail.com. thanks in advance.
完成的
Having the same issue with iPad 2 right side of screen not responding and thus I can't join wifi networks as the 'Join' key or button is on the right! Wits end crap...
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
keith harris, usually when the touch screen does not work in a specific area, it is the digitizer that has failed. Of course you should always try a reset/ recover on your device first, if it is unsuccessful you will have to replace the front display assembly. Follow this guide for that, and the part is available right here as well as many other places. There are those that say you can separate the digitizer from the LCD, I personally have not had any success with it due to the lack of proper (expensive ) equipment for that task. Hope this helps, good luck.
iPhone 4S Screen图片
产品
iPhone 4S Screen
$34.99
这个答案有帮助吗?
得分 3
12条评论:
Thanks for your help. The screen works perfectly now. I had the network connection issue after everything was said and done but found the solution of switching the time and date in the answers section. Everything is working fine now. Thanks again
完成的
Can you please explain better what was the solution you followed step by step? PLEASE!
完成的
I'm having the same issue with the letter "P" I've changed the screen and still has the same issue. Weird. Something control the letter "P" or that area?
完成的
Tried multiple screens & done everything. Still, no letter "P".
完成的
Still no letter P... 50 screens. No letter P.
完成的
显示更多的7条评论
添加一条评论
Well I had the same issue.dropped my iPhone 5 and thereafter a part of the the bottom screen became unresponsive.what I did was to apply a little pressure to those areas and it came back to life.hope it helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
keith harris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 120,243
