跳转到主内容
加入维修社区 - 创建账户
My MacBook Pro won't recognize it's internal hard disc
Hi guys
A few months ago my computer froze completely after getting overheated, and since then my computer hasn't been able to find my internal harddisc. However, when I checked if it was possible to salvage anything from the harddisc, it turned out that it wasn't damaged at all! So it has to be either the cable or the motherboard. This is how my motherboard looks like:
To me it seems like there is a little area where the nodes have been fried a bit (yellow color), but I'm not sure.
So the question is: Is my motherboard fried or is it just the cable that needs to be changed?
One more thing. I still use my computer with an external harddisk, and on one occasion it got really warm, but was still functioning. Then I managed to drop it on the floor. After I then restarted the computer, it suddently managed to recognize the internal harddisk.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Can you supply the last three digits of your serial number so we can correctly ID your system and its logic board.
完成的
I came across the same issue where my internal hard drive was not being recognized. I tried tesing multiple SSD's and regular standard hard drives, issue still occurred. I tried testing with external adapters, still issue occurred. Then I switched out the cable, issue fixed! Also changed out the hard drive to an SSD 480GB and switched out the RAM to 16GB RAM.
完成的
添加一条评论
2个答案
已选择的解决方案
This type of problem has become so prevalent that I now stock two each of both the 15" and 13" cables. I would replace the cable and see if the issue is gone. (use a NEW cable, not used): MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If does appear you have some corrosion damage as the solder pads of the vacant chip location look discolored.
Did you get your system wet (damp) at some point?
I would remove the battery and with distilled water (not tap!) scrub down the areas which appear discolored. Make sure not to snag any of the small components with the cotton swabs. Once you've finished go over the same places again this time with a good quality isopropyl alcohol (the higher the proof the better). This will help in drying out the water. Give your logic board a good day to finish drying, then reassemble. If the HD SATA cable connections look discolored I would replace it.
You may need to retouch the solder joints. If you've not worked on such small components I would recommend bring your system into an authorized Apple service center for them to fix your system (after you have cleaned up the corrosion).
这个答案有帮助吗?
得分 1
3条评论:
Thank you very much for your answer!
I don't think my computer has ever been exposed to water, but I will do as you suggested.
完成的
Use 90% isopropyl alcohol to clean any electronics. Not water!!!
完成的
I think you're confusing tap or spring water here. Yes, these would be bad! Not the base water its self, its what is dissolved within the water that kills the electronics! Salts, metals and other junk. Its this other stuff you need to worry about unlike pure distilled water which is pure H2O.
Distilled water is just fine when you're cleaning off something that is water soluble or trying to neutralize something that is acidic or alkali. You do need to dry the parts completely before you power the system up first.
完成的
添加一条评论
添加你的答案
GulSno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 12,738
