跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
Epoxy / glue for back case
The iPhone (2g) case is made of several aluminum parts that have been glued or epoxied together. The bit of aluminum that the head phone jack is screwed to came unglued from my case. Just wondering what would be the best stuff to use to reattach it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Fix-All Adhesive is a great all-purpose solvent glue and sealer. It seals and repairs almost any surface easily and quickly. http://www.supergluecorp.com/super-glue/... FixAll
这个答案有帮助吗?
得分 1
添加一条评论
I’m very far from the top of the page where you were discussing UltraDome. I have worked with epoxy resin. It yellows…I can live with that. Pretty much. But you really have to have a lot of things thought out very well beforehand or fixing it afterwards is a real DRAG!! and sometimes impossible.
http://www.parsonadhesives.com/partite-p...
这个答案有帮助吗?
得分 0
添加一条评论
Well i had used Epoxy Seam Sealers for the floor pan bonding in car, it works great. Hopefully it will solve your problem too.
Thanks for the post
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
scampy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 5
总计 1,945
