跳转到主内容
加入维修社区 - 创建账户
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
macmods adapter - use
Hi, Im using the macmods adapter and have some questions, (Im apologize about my english):
Do someone knows if its ok to connect to 1 tube lcd an inverter designed to feed 2 tubes?
The imac intel inverter its connected to a original 2 tubes lcd, but the macmood includes an Y adapter to use a single tube lcd as replacement, I notice that the one tube lcd I use goes to hot on the bottom (where the tube is placed) and perhaps is cause the inverter doubles the current nedded for the tube.
I dont know to test it, I mean how to measure and compare the original current on the 2 tubes lcd vs the 1 tube replacement lcd.
Thanks a lot
Alvaro from Uruguay
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
It might help if you can give us more information about the macmods part (post a couple of images) and where you got that part from.
完成的
添加一条评论
1个答案
已选择的解决方案
I think this is a question you should be asking the vendor/manufacturer. You'd be much more likely to have people with experience and knowledge of this 3rd party hardware there than here.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alvaro B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 135
