跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Why does my iPhone has some grey spots on the screen?
I have accidentally fallen on my iPhone and hit on the screen with my elbow. I have noticed some grey spots on my display now.
These grey spots (5 of them) are visible on the screen even when the phone is on standby mode. These grey spots are not always in the same shape too.
The screen is intact and the touch functionalities are fine too. The touch on the grey area is also getting recognised fine.
I had thought of changing the display but when am noticing that these spots are becoming smaller, now I dont know if its a good idea to change the display.
Can someone please tell me what should I do now regarding these grey spots?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
9条评论
Hi, I have tried to rub on those grey spots and they seem to move. I have succeeded in rubbing those and made them to move till the sides of my phone from centre. But they dont move out completely.
完成的
Hi, Can these be dead pixels??? If yes, then how should I get my iPhone display back to normal.
完成的
I have the same problem... should i change the display?? what should i do?
完成的
I would think that they are dead pixels and would consider changing the display. It would also work a lot better for you if you ask your own question and give as much detail as you can. There is a link on the right hand side of this page "Ask a question" and if you click on it you get to tell your story and tell us what happened and what you did to try to fix it. Right now your question shows up as an answer to an old question. Good Luck and give it a try.
完成的
look my iphone has gray spots but it wont take off do u guys think that apple could fix this problem
完成的
显示更多的4条评论
添加一条评论
7个答案
已选择的解决方案
Hi, thanks for your response machead, I waited for am answer and later I have got my screen fixed at a service centre.
这个答案有帮助吗?
得分 1
添加一条评论
You can try this
http://knoxing.com/2007/08/05/iphone-stu...
这个答案有帮助吗?
得分 1
添加一条评论
i also accidentally fallen on my iPhone but in beginning there was not a spot but gray lines appears, with the passage of time its become on big spot now its is turning smaller i guess the usage create this i am totally agree with this " rubbing formula" and i am on it, if line become spot and spot become smaller then may be its remove or move to the screen corner.
这个答案有帮助吗?
得分 0
添加一条评论
idiot
这个答案有帮助吗?
得分 0
添加一条评论
It is broken. You need to replace a new one.
这个答案有帮助吗?
得分 0
添加一条评论
On my ipod I hit it by accident and on the top you can see colorful spots with red,yellow, and green I need help. Will it go away
这个答案有帮助吗?
得分 0
添加一条评论
Ignore Bob, he's an idiot for trolling
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raju 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 30
总计 79,357
