跳转到主内容
Eighth generation of the Honda Civic.
57 个问题 查看全部
'06 Honda Civic stereo code?
I removed the battery in my 06 Honda civic, after I put the battery back my radio/stereo wouldn't work and it kept on asking for a code to put. can anyone help me out on what code I should put?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
Hi Josiah, I recommend you take a look at the guide on the below website:
http://www.freeradiocodes.com/brands/hon...
It will show you exactly how you can get a radio code for your Honda Civic for free.
完成的
Yeah I had this samee issue actually a while back. You can get a radio code here: https://radiocodevault.com/honda
Hope it helps mate! :)
完成的
hi
I need code for my Honda Civic 2007
I am in Saudia and i am unable to find the code :(
any body who can help me?
完成的
hi
I am in Dubai and i am unable to find the code :( any body who can help me?
Tried several times the same solution on the https://radiocodevault.com/honda/ but it says VIN Invalid.
完成的
添加一条评论
6个答案
已选择的解决方案
Josiah, give this a try:"
  1. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn car to ON II(radio powers up)
  2. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn radio off
  3. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)
  4. Hold 1 & 6 buttons on radio
  5. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)While still holding 1 & 6, turn radio on
  6. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Write down the 8digit number that should display
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
I got my Civic’s radio code from this site: https://radiocodevault.com/honda/ its great, got my code in like.. an hour I think? It was sent straight to my email.
MUSIC FINALLY AGAIN! :DDD
这个答案有帮助吗?
得分 3
添加一条评论
Many times there is a sticker on the left side of the glove compartment containing the radio code. Check there first, because sometimes the Honda dealer can charge you to look up the correct code.
这个答案有帮助吗?
得分 1
添加一条评论
Donner moi le code pour la radio Honda civi 2006
这个答案有帮助吗?
得分 1
添加一条评论
Your radio code is unique to your radio, you will need your radios serial number in order to successfully generate a radio code. visit the below website which will explain how you can find out the serial number of your radio and also how you can generate a radio code for your honda civic.
Check it out here... http://freeradiounlocking.com/brands/hon...
这个答案有帮助吗?
得分 0
添加一条评论
Je veux le code pour ouvrir la radio de ma Honda civi 2006
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josiah 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 47
过去 30 天: 248
总计 48,240
