跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
no signal
please i have wifi in my phone and no signal sim i change blue coil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Is this cable connected?
完成的
添加一条评论
3个答案
已选择的解决方案
Go into ( Settings - General - Date & Time ) you will see "Set Automatically" If it is set to "ON" flick it to "OFF" wait a few moments then flick it back to "ON". In the case you do not see results within a few moments give it a minute or two to reconnect to the network and update your settings. Make sure your sim card is inserted while you do this.
这个答案有帮助吗?
得分 2
添加一条评论
Sometimes that will occur if your date and time are not set correctly. Occasionally when the battery is disconnected, the phone will stop automatically updating the date/time correctly. If they are incorrect, correct them and restart your phone. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
http://www.youtube.com/watch?v=AXwQZy0hw...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mido 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,020
