no signal
please i have wifi in my phone and no signal sim i change blue coil
Go into ( Settings - General - Date & Time ) you will see "Set Automatically" If it is set to "ON" flick it to "OFF" wait a few moments then flick it back to "ON". In the case you do not see results within a few moments give it a minute or two to reconnect to the network and update your settings. Make sure your sim card is inserted while you do this.
这个答案有帮助吗?
Sometimes that will occur if your date and time are not set correctly. Occasionally when the battery is disconnected, the phone will stop automatically updating the date/time correctly. If they are incorrect, correct them and restart your phone. Good luck!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,017
1条评论
Is this cable connected?
由 Chandler Skinner 完成的
