跳转到主内容
Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
19 个问题 查看全部
No longer charges, whether on or off
My Logitech H800 wireless headset used to charge when on and in use, or when off and not in use, but now does neither. I have tried using USB from computer, from wall, changing different USB cables, everything I can think of. Where can I get a replacement battery pack for the Logitech H800 wireless headset?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
11条评论
Purchased a replacement battery pack from ebay: NEW Replacement Battery for Logitech H800 Wireless Headset. Now to see if I can install it without breaking any of the connecting wires ...
完成的
I think you'll Be fine. Just like any repair, take your time and always inspect it first before disassembling :-) If you need help, ifixit answers will be here
完成的
Mabel Xu,
were you able to fix your H800.
完成的
replaced battery successfully, but headphones still did not charge ... ended up calling in to claim warranty and get a replacement, their customer service is quite good.
完成的
I put in the replacement battery pack, but that one soon stopped charging as well :( not sure what components on the boards to test to revive these headhpones, I have 2 pairs, both the same behavior.
完成的
显示更多的6条评论
添加一条评论
3个答案
已选择的解决方案
The problem most likely is not the battery but the connection between the micro USB and the headset. The micro USB's miniature connectors are probably broken off. That happened to mine. I had to take the headset apart and solder the connecting pin back. You will need a magnifying glass to see it. It is very tiny...
这个答案有帮助吗?
得分 7
7条评论:
going to assume you cant solder across those pins and have to do each one.
完成的
My USB port broke completely. Have to replace it. What type of micro-USB port is the correct replacement part? 5pin type B???
完成的
could you give a really zoomed in picture of what the repaired micro USB socket's connections should look like? thanks
完成的
I ordered the parts at amazon .. as soon as they are here, the electronics-workshop guys at my workplace will do the soldering. I'm so exited .. You will get your photo, but it may take 2-3 weeks. The socket has 5 pins at its backside .. you should see those. The are SMD-soldered, so don't expect any big conections ..
完成的
I got the USB-port, the workshop did the soldering. I'm sorry I cannot deliver the Photo, I don't have any camera with a macro objective for THAT small parts. Long story short: It's possible to repair/replace the USB-port but you have to have a lot of practice and/or a lot of knowlegde about soldering. Even the guys at the electronics workshop at the university were waiting for the one single colleague thats experienced in SMD-soldering.
完成的
显示更多的2条评论
添加一条评论
Mabel Xu, depends on where you are located. Part number for the battery is 993-000565 and it is available at places like this as well as right here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
You can also purchase the replacement battery directly from Logitech here but they ship only in the US.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mabel 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 103
总计 38,147
