跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
4S reboots automatically after shutdown (not while plugged to pc)
Hello everybody!
I have a 4s 32gb with this problem: when I turn it off (holding on-off and sliding on "turn off"), it reboots itself immediately after.
The problem doesn't occur when the iPhone is connected to the pc. Why?
I've already tried to replace the battery, but the problem persists. I've also tried to reinitialize in DFU mode, withouts results. Do you know what it can be? Battery connector, charging connector, on-off button....?
Thanks
Teo
ITALY
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
i have the same problem, nothing suggested online worked.
my phone worked fine before i upgradet to IOS7.x.x which sugests the problem is a software bug, and not hardware related ( unless the hardware got faulty during the software upgrade, which is dobtfull )
I think apple put this issue on the code on pourpose to force people to buy iphone 5's
完成的
Nuno, same thing happened to me right after the update AND my battery runs low faster than it used to...
完成的
I have the same thing problem … Uhmm … Yesterday i wemt to repair shop to change the Battery then after that . It started to automatically rebooting my iphone4s .. i tried your suggestions and comments but .. still it reboot itself Either Connected or Not Connected to charger … please help me :( im frustrated about this..
完成的
添加一条评论
3个答案
已选择的解决方案
open you iPhone and test it. unplug the power cable first. turn off device and check. if its still reboots, unplug the dock connector and check again....
have a nice repair
iPhone 4S Dock Connector Replacement
这个答案有帮助吗?
得分 0
6条评论:
Sorry iwillfix, what do you mean with "test it"?
I have to:
1 - unplug the cable
2 - turn off the device and check if it reboots again
Those 2 points I've already done.
Then you said to unplug the dock connector and re-check again in the same way?
Sorry for my english, I'm italian =)
完成的
so did the device still booted up by itself when the power button cable was disconnected? yes? cable ok.
now do the same thing with the dock connector.
turn off phone, open and disconnect dock connector cable, turn device on and back off again to look if it boots by itself
btw your english pretty good ;-p
完成的
Ok, I've disconnected the dock connector: after shutting down the device it doesn't reboot itself.
I only hope that it's a problem on the dock connector and not on the "mobo"...yyyyyap! XP
完成的
replace the dock connector and you will be fine :-)
完成的
DONE! Thx a lot, iwillfix! ;-)
This is a great website!
完成的
显示更多的1条评论
添加一条评论
My 4S did the same thing. I took it Apple and was told to buy a new phone. Another post on this site suggested cleaning the docking connector with isopropyl alcohol. I carefully did it with a tooth brush and IT FIXED IT!!!
THANKS
这个答案有帮助吗?
得分 0
1条评论:
The toothbrush solution don't work for me.
I open the phone and disconnect the battery connector and wait for a couple of minutes and after connect and turn phone on.
No more sound and reboot problem on my 4s...for now...
完成的
添加一条评论
I shut down using the two bottoms at the same time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Teo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 11,192
