跳转到主内容
Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
31 个问题 查看全部
What's the cable pinouts?
i have been looking for the pin-outs of the ipod shuffle 4g cable for a day now, and i can't find anything correct, only the 2g witch is apparently not the same one as the 4g. i really need help fast. just to make it easier for you to answer i included a picture, so if you know it please answer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Valen S, one of the things to remember is that the Shuffle 4G has a few IC's of unknown type as part of the cable, so we are not sure yet of exactly what they do and how they impact the cable. The pinout itself is as follows ( I am using your markings)
iPod pin 4 to USB pin C => USB DATA - / Left Channel
iPod pin 3 to USB pin B => USB DATA + / Right Channel
iPod pin 2 to USB pin A => GND
iPod pin 1 to USB pin D => Vcc
Hope this helps, good luck.
这个答案有帮助吗?
得分 4
4条评论:
hmm, weird that nobody has ever taken one apart. the ic stuff is probably a way for apple to earn money :(
完成的
Yup, that is what makes those cables special and costly ;-)
完成的
Thanks, guys!!!
完成的
Did the correct pinout get you comnected or is the PCB necassary to establish a connection?
完成的
添加一条评论
I have found a PCB with several CMD electronic components like IC's, capacitors and resistors inside USB connector of iPod Shuffle 4g cable.
这个答案有帮助吗?
得分 1
2条评论:
Hi im making a homemade cable so is it posible to make it witouth these components? please answer ASAP Thank you
完成的
Did you do it??
完成的
添加一条评论
添加你的答案
Valen S 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 90
总计 17,377
