跳转到主内容
加入维修社区 - 创建账户
Mac mini 最初于2005年1月发布。
Upgrading iMac with Mac Mini
I love the iMac known as iLamp or volleyball or whatever else...
Has anyone replaced the innards with a mac mini?
That's my next project! Any thios would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Can you please be more specific on what you would like to do?
完成的
funny, rab77hp, I seem to be able t understand what Jack wants .... hot that hard to see he wants to move the mac mini into the Imac case, and use the imac screen ....
完成的
Then if I'm understanding correctly- he wants to completely swap out the 'innards' or the iMac with the mac mini.
完成的
添加一条评论
4个答案
最有帮助的答案
I can see that being a fun procect - but not sure if the screen on the iMac ends up using a standard cable with pinout you can connect to the video port of the mini. I guess you need a circuit diagram for the iMac
这个答案有帮助吗?
得分 1
2条评论:
Corrected Spellings
完成的
you missed the spelling of 'project' then! lol :)
完成的
添加一条评论
Hi there,
I have the same project with my old G4 iMac
Did you finally managed to do this?? If yes how did you manage the screen connection??
Thanks
Joel
这个答案有帮助吗?
得分 0
1条评论:
Post this as a separate question.
完成的
添加一条评论
Nope. Screen issue was a show stopper!
这个答案有帮助吗?
得分 0
添加一条评论
but there is a solution to connect the original screen to a mini
CLICK - but be careful - if you don't understand chinese - it will be very hard to get ;-) (google could help - but not so much)
there is a topic about that on macrumors, but last point was the link to the page above.
i have an iLamp 17" and i'm also planning a "technical refresh"
but instead of a mini i will put in a mini itx board with a core 2 duo - the mini wont help anyway - the optical drive is not usable in the iMac, the whole thing makes only sense when put in without the case and in the end - the mini is only a mini itx board - so why should i buy a pretty expensive mini itx board without the abilitys that some other boards have (mine has 2 vga and a hdmi output, 6 usb 2.0 and since it's a santa rosa board - i'm able to run the snow kitty on it
i'm thinking abit getting a different lcd panel in the g4 - the hanns g. 17" have the same aspect ration and the same resolution as the 17" iMac g4 - but i have to figure out how to put everything together in the lampie
这个答案有帮助吗?
得分 0
2条评论:
Wow, Japanese...
So problems are :
-optical driver (should not be so big problem)
- how to fit all ports ont he circular base (firewire, usb...); looks quite difficult
-THE SCREEN (this one is quite tough)
Well, I keep this project in mind and will see this one of this day. I do not have enough time now.
Thanks
完成的
The optical drive is one of the biggest issue if you want to keep the original design - a slot in drive can not be used with the mechanism on the g4, so you would need an ultra thin drive with a motorized tray
i would love to hafe a touch screen in my 17* - but since the most drivers are for windows based machines - there would be not so much chance to get a working one with the correct size and aspect ratio
完成的
添加一条评论
添加你的答案
JAck17 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 7,150
