跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Is the battery same as the 13" MacBook Pro?
Is the battery on A1342 MacBook the same as the one on the 13" MacBook Pro?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Which 13" MacBook Pro?
完成的
Yes. I can second this. The battery connector for the a1278 MacBook Pro (2009-2011) and the a1342 Polycarbonate MacBook (2009-2010) are the same. In fact, you can power an 1342 MacBook with an a1278 battery. However, the battery from an 1278 MacBook will not physically fit in an 1342 MacBook.
完成的
添加一条评论
3个答案
已选择的解决方案
If you're still unsure of this, here's what I see. If you compare the replacement batteries that iFixIt offers for the A1342 13" Unibody MacBooks with the A1278 13" MacBook Pros, you'll see that each has a different Apple Part Number and Product Code. It also appears that they each have their own distinct design that would make them incompatible with other models. So to answer your question, I'm fairly certain that they are not the same batteries and would not work in models other than those that they were intended to be in. Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Go here when you know which 13" MacBook Pro you are referring to compare: http://fastmac.com/laptop.php
这个答案有帮助吗?
得分 2
添加一条评论
yes it is the same
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marc Chan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,383
