跳转到主内容
Can I use the iPod Nano charger as a USB cord?
My sister just got an iPod Nano 3rd gereation and she only has a charger. Will that work as only a charger or can I hook that up to my RCA 300W stereo and play it or do I have to buy another crd to do that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Removed a few non-answers. Let's see if we can actually answer the question. :-)
完成的
Thanks. :) I had tried to answer the question, but I wasn't exactly sure what was being asked...
完成的
添加一条评论
3个答案
最有帮助的答案
The charger for the iPod is a USB cable, that you can plug into a computer or a wall charger. I haven't seen any stereos with USB input, but that would be cool! The stereo would have to specifically have iPod support to work.
这个答案有帮助吗?
得分 2
1条评论:
agreed +
完成的
添加一条评论
you can not transfer music to it by the stero you do have to buy a cord for that to the coumputr thank you and have a nice day
这个答案有帮助吗?
得分 0
添加一条评论
Yes, and no....
It probably will not work the way you wish it would, to be able to play the iPod through the stereo. However, if you designate part of the iPod as a hard drive *and* you store songs on that hard drive in mp3 format *and* your stereo will play mp3 files from a USB memory device it *should* work.
See Apple's support for how to designate part of your iPod as a Hard Drive or use this link:
http://www.ilounge.com/index.php/article...
Another option would be to use an Aux input on your stereo with a cable like this:
http://www.mac-pro.com/iPod-Headphone-Ja...
Note: If you use this cable, turn your iPod volume all the way down and your stereo volume to less than 1/4th and turn the iPod volume up very slowly. If the iPod volume is too high you will get bad distortion. You want your stereo to do most of the amplifying (it was designed for that).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Taeylor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 3,778
