跳转到主内容
加入维修社区 - 创建账户
Not Booting
I have this problem with two Macbook Pros (2011 & 2012 models).
I've replaced the RAM, battery, harddrive & power supply.
There's no problem with over heating.
I can run the Mac diagnostic screen for hours or boot from the CD.
I went to the Apple Genius bar and was told to replace the logic boards.
It appears to be a boot-no-more switch that's been flipped in the BIOS. has anyone found a way to roll back the BIOS or get around what appears to be built in obsolescence?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Apple uses a version of EFI for the BIOS - As far as I know there is no logic to react that way. If you think the firmware is bad see if there is newer EFI firmware available Apple TN on EFI firmware. Q - Do you have a system password set?
完成的
i can't switch on my laptop ? no any lights at all,charging point also no lights ?
完成的
添加一条评论
1个答案
已选择的解决方案
Try zapping the PRAM to reset it.
Resetting NVRAM / PRAM
Shut down your Mac.
Locate the following keys on the keyboard: Command (⌘), Option, P, and R. You will need to hold these keys down simultaneously in step 4.
Turn on the computer.
Press and hold the Command-Option-P-R keys before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the second time.
Release the keys.
After resetting NVRAM or PRAM, you may need to reconfigure your settings for speaker volume, screen resolution, startup disk selection, and time zone information. If issues persist, your Mac's logic board battery (not a portable Mac's rechargeable battery) may need to be replaced. The logic board battery helps retain NVRAM/PRAM settings when your computer is shut down. You can take your Mac to a Mac Genius or Apple Authorized Service Provider to replace the battery on the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Glen Searle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,260
