跳转到主内容
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
6条评论
How did you clean it? Did you check the components while you cleaned it?
完成的
How I do ? i already tried to reset the controller and its not working with the USB cable ...
完成的
all the components are fine they have no breaks or anything
完成的
yes, I was wondering how you cleaned it.
完成的
with a scott towel
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
这个答案有帮助吗?
得分 1
添加一条评论
you may need to re sync it to the console.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicolas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 921
