跳转到主内容
it doesn't power on after screwing the logic board.
I replaced the key board and connected all connectors without screwing things, put the lower case and turned on. It worked fine. But after screwing all things, it doesn't power on.
I unscrewed the logic board and put it back, then connected all and tried. It worked fine sometimes but not every time.
I'm doubting that this is caused by the metal plate next to mag safe or below connectors that maybe getting GND. Or small pins on the logic board that may be detecting if the lower case is closed. I'm sure it was closed even not screwed tho.
Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I suspect that you have placed the screws incorrectly, i.e., you have a long screw in a short screw hole and it is shorting out the board. See if it works without the bottom on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
alexpk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 87
