跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
20 个问题 查看全部
Why won't my music play?
My music will not make sound on my phone. It shows to be playing, but no sound can be heard. It does not work from the phone or using Bluetooth through my truck speakers. Calls and alert sounds work fine. I can even preview songs on iTunes, but my music has no sound. Please help.
Chris
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 55
32条评论
does it work through headphones?
完成的
Nope. It seems like it is muted.
完成的
Chris, this is happening to me... ever find a resolution? Feeling like my only option is switching the phone out.
完成的
I need help with my iPhone too. It's having the same problem but I can only hear the music through headphones.
完成的
my i phone 4 freezes when in the music program why?
完成的
显示更多的27条评论
添加一条评论
11个答案
已选择的解决方案
Chris, you may have issues with your headphone jack. It will switch the speaker etc. off when a set of headphones is plugged in. So if the jack is stuck, your phone will turn off the external sound. Try to insert and remove a headphone jack a few time in rapid succession. You can also try to clean it with some isopropyl alcohol, a few puffs of compressed air, as well as a small non-conductive cleaning rod i.e. toothpick. If that does not help you may have to replace the headphone jack. Follow this guide for that. The part is available right here as well as many other places. Hope this helps, good luck.
这个答案有帮助吗?
得分 8
4条评论:
I tried the earphones. Didn't work. I did play some YouTube videos and the sound works on them. It only doesn't work with my music.
完成的
Thanks Man! it helped!
完成的
if i rapidily insert and remove a headphone jack a few times in rapid succession then also its not working -_-
完成的
Hey Chris, I actually had the EXACT SAME problem, and I fixed it by simply soft resetting my phone (hold down the sleep/wake and home buttons simultaneously, it will make your phone go dark but once the apple logo appears on your screen you can let go). I went and tried my music after that and it worked perfectly. Hope this helps!!
完成的
添加一条评论
Have you tried to close out of the app? (double click the home button and swipe up to close the app). I would suggest to clean out the headphone jack with an air can and then plug those in. Turn up the volume when you are playing a song. It should say headphone volume and nothing else. There are a few useful tips for sound issues here as well that you can try: http://vkrepair.com/iphone-6-2/iphone-6-...
这个答案有帮助吗?
得分 5
1条评论:
My iphone does this when charging!
I found this to work.
Turn on music
Then
Swipe screen from bottom to top
This brings up "short cut" screen if you will!
This will show what music is playing!
Under that mine shows
(Dock convector)
Rich on this!
It shuld show other options!
完成的
添加一条评论
Just had the same problem - headphones working OK with calls etc, but when trying to play music, the music timer wouldn't move on and no sound - like it was paused but I couldn't un pause it.
Seem to have fixed it by going Settings, Music, and turning on shake to shguffle and sound check, I've since turned them off and it's still working fine.
hope that helps
Chris
这个答案有帮助吗?
得分 3
7条评论:
for some reason this worked for me, although i had the 2 settings turned off initially, I turned it on and then off and now my iPhone 4 plays music and doesn't stop after a few seconds. It is still a good idea to clean out the charging port though.
完成的
"Have you tried turning it off and on again?" worked for me.
完成的
yes, i have tried tried turning it on and off
完成的
On and off the sound check worked for me. Thanks! The sound connects again on the BT
完成的
Worked for me too!!! Thanks soooo much!!!!!!!!!!!!!
完成的
显示更多的2条评论
添加一条评论
When you switch to a home screen and try to press volume buttons up and down, will the volume indicator show up and move up and down? Sometimes it happens that charging port has a short and phone thinks it is plugged to the dock station, and it does not play music trough loudspeaker as well as does not allow to control volume of the phone.
If you have this symptoms i suggest you to change charging dock cable, this should fix the problem
V.
这个答案有帮助吗?
得分 2
2条评论:
PERFECT thanks
完成的
I have an iPhone 5, music was not playing through headphone or earbuds, I saw this and tried the volume switch with the earbuds in, turns out there is a different volume control when you have earbuds in. I somehow had turned the volume all the way down. Thanks!
完成的
添加一条评论
Jon,
Have you tried putting in the headphone jack and and then taking it out? Repeat that a few times.
After that, check the volume. That sorted mine out!
There is an entry about it earlier in these posts.
这个答案有帮助吗?
得分 0
1条评论:
when I have my Bluetooth in it will not let me listen to music from the Bluetooth. Any answers or questions. I have a iphone 4.
完成的
添加一条评论
I just had this same issue! I read the first comment about the headphone jack and then just blew into the hole like an old school SNES cartridge fix, It worked fine right away!
这个答案有帮助吗?
得分 0
1条评论:
yes! blow in the headphone jack! it works!!
完成的
添加一条评论
Try putting the headphones in and pulling them out again, repeat.
这个答案有帮助吗?
得分 0
添加一条评论
I was having a problem hearing the music also, then I realized the volume bar was all the way down to nothing. Felt stupid :) but in my defence, since I had not adjusted the volume at any time that was not the first place I would have checked.
这个答案有帮助吗?
得分 0
添加一条评论
Try using a pluging in a different charger. Like an old iPod charger or just a different one that fits your port of course. It worked for me and for some reason it always happens to me and I just try everything until it works and so far this works very single time.
Goodluck(:
这个答案有帮助吗?
得分 0
添加一条评论
It really works with toothpick n centre of charging port theres a really one small hole that i poke n it really works thnks again remember one small hole in the centre of charging port try it everyone it really really works thnks again bt dont break the toothpick
这个答案有帮助吗?
得分 0
添加一条评论
If you are playing videos or music and can't hear them, play a song from your library and click the little box like bottom to the right of your volume line and make sure it is on iPhone.
这个答案有帮助吗?
得分 0
1条评论:
I'm just telling y'all know iPhones are no good
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 277,972
