跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Questions on changing out HD to SSD.
If I change out my HD to SSD will I lose all my apps?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Use this to duplicate your drive: Universal Drive Adapter
I like SuperDuper: http://www.shirt-pocket.com/SuperDuper/S...
Universal Drive Adapter图片
产品
$24.99
这个答案有帮助吗?
得分 1
添加一条评论
Carbon Copy Cloner is unbelievable. Best to save all media, documents etc on an external drive if you can, that way the clone process is faster. The best part is that the clone you make is bootable, so you don't need to reinstall the OS etc, you just boot from the external drive (hold down the option key on startup and chose the external drive to boot from), use that to format etc the new drive using Disk Utility and then clone you "whole" computer back to the new drive.
I just did that and apart from the 30 minutes it took to clone my whole computer and clone it back onto the new SSD (2.5” SSD SanDisk Extreme II) , the swapping of the drives took about 5 minutes. The step by step guide was perfect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ayush 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 361
