跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
memory RAM stuck inside at the bottom slot
So basically, I did a mistake when I tried to upgrading my MBP memory RAM. After I removed the original RAM, and when I tried to install the first RAM to the bottom slot, it did not installed correctly but I already pushed it too hard so now it just stuck there without being recognized by my MBP. Then I continued to install the second RAM into the top slot (each 8GB). Then when I turned it on, it says that the RAM is only 8GB instead of 16GB (obviously the bottom RAM did not installed correctly that's why).
So now my question is, how to remove the stucked memory RAM out from the bottom slot of my MBP 15" mid 2012?
Thanks in advance,
Tobi
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
First remove the easy one then try to wiggle the other one loose, here's how: 2012年中 15寸 MacBook Pro 一体化机 RAM 更换
这个答案有帮助吗?
得分 2
添加一条评论
pull it because i believe you just broke the slot or ram card so you will have to take a look once you pull it out as hard as you can without breaking the ram
这个答案有帮助吗?
得分 1
添加一条评论
What if it is the top ram chip that is wedged in at an angle
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tobi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 7,191
