Broken connector replacing Logic Board
Hello everyone,
today i was disassembling my macbook pro a1260 for trying to fix my logic board.
Arrived step 14 of the guide, i accidentally broke the first connector on the left, near the two connector of the left fan.
if i fix it with some glue could it work again? Is there a place to by just the connector?
Then, if it's broken, could my laptop work again? (also without a component, it was a my old macbook and i just want to try to fix it)
Sorry for my english but I'm italian.
Thanks in advance
cicchilitto, first let me say that there is nothing wrong with your English. Second, it is never a good idea to glue a connector. It is very seldom that glue will hold and that it makes proper contact. You should give us the last three digits of your serial number so we can properly identify your computer and your logic board. Also, it will help if you post an image of your board and connector, so we can see what you see. It is important to check the solder pads as well as the traces.
由 oldturkey03 完成的
Thanks oldturkey03,
I edited the question with a picture of my board.
The last three digits of the s/n are YJZ.
由 cicchilitto 完成的
Do this specs look right?
2.4 GHz Core 2 Duo (T8300)
Intro Date: February 26, 2008 Disc Date: October 14, 2008
Order No: MB133LL/A Model No: A1260 (EMC 2198)
Subfamily: Early 2008 Model ID: MacBookPro4,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 200 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
Complete MacBook Pro "Core 2 Duo" 2.4 15" (08) Specs.
your link to an image requires me to sign in. I suggest you post the image with your question. Check this guide to see how to add an image to your question. Adding images to an existing answer
由 oldturkey03 完成的
I edited as you suggested. Thanks a lot for your patience!
Yes, specs are right!!
由 cicchilitto 完成的
Just a question for cicchilitto, do you have any previous soldering experience?
由 Owen Cunneely 完成的
显示更多的3条评论
